Mon bateau est un EDEL
Sir sails in a convertible, when the sun is at its zenith and the other sailors are sweating in their closed sailboat, you will be cool with your sunroof and by adding a canvas against mosquitoes you will sleep under the stars !!
si tu envois ton plexis ils te feront les trous au même endroit sur ton nouveau hublot
