- Ce sujet contient 22 réponses, 6 participants et a été mis à jour pour la dernière fois par Brian, le il y a 2 années et 7 mois. Ce sujet a été consulté 15359 fois
26 février 2022 à 10 h 44 min #30425
I found this picture which looks more like what I was expecting (originaly published in this classified ad) :
You can open it and zoom to see it better.
But again, I don’t know this boat that much :)
26 février 2022 à 11 h 26 min #30427Hello,
Next time, within a week or two of going to the boat, I’ll take pictures and post them.26 février 2022 à 15 h 51 min #30429That looks like a much more robust setup then what is on my version. I do not know all the proper terminology, but the portion that is attached to the cabin roof is much « beefier » then mine. If it was possible to get both the mast foot and the portions that are attached to the cabin roof recreated, then I would be able to install them both.
26 février 2022 à 15 h 57 min #30430I would probably need to adjust the shrouds to compensate for the additional height of the mast step, but I think that could be made up within the span of the turnbuckle.
26 février 2022 à 16 h 03 min #30431if i was to get accurate measurements or even adequate pictures it might be possible to have someone fabricate it. I’m jealous… the French versions do indeed seem to be built to a higher standard:)
27 février 2022 à 22 h 40 min #30438Yep Ian
If you have an account on Facebook, go to « Edel Sailboat Owners » Group.
It’s a group in English from Canada I think, and contact Bernard Buzz Cox.
I think he could help you.
28 février 2022 à 21 h 35 min #30442thanks a lot! I will check it out.
6 juin 2022 à 17 h 14 min #30826Hi Ian, I just acquired the same problem. I was wondering if you found a solution.
https://youtube.com/shorts/6VOJW9WT4PI
Here is mine. I think it would be similar to yours.
